Gen2 3sgte Injectors
Postby solitaire » Wed Jan 17, 2007 10:57 am
Hi,
I have searched, everything seem to cover using 3sgte injectors in other engines so here i am. - my apologies if i missed a thread that has that information :(
I have a gen2 3sgte, can i simply plug in later gen injectors and it will richen the micture a little or do i need an aftermarket computer?
Reason im asking is i will probably end up using them eventually... thought i may as well do it now if i can...
AE92, KZJ120, KDJ120
solitaire
Postby big_boy » Wed Jan 17, 2007 11:17 am
why do u want it richer?????
how much bigger are the later ones your looking at ?
after market ECU is normal needed with bigger injectors unless your running lean & can calacute the size you need to go up exactly
have you seen the therid on injector enlargeing if its just a slight bit it might be what you want
big_boy
Postby solitaire » Wed Jan 17, 2007 11:21 am
Well shes running at about 12a/f and i would prefer it sat on 11.
The injectors in it are 440cc and the ones in the later gens are 550cc...
Id prefer not to mess with the existing ones as that would be extra expense... i will go to 550cc eventualy once i have a link (later this year)
So basically the injectors will squirt roughly 25% more fuel in each time it fires right?
solitaire
Postby big_boy » Wed Jan 17, 2007 11:30 am
well thats all fair a nuf then yes the new injectors will run about 125% give or take a bit
witch you may find a bit ritch id say it woul came out about 10 ish but i dont know your ECU well anuf to grantee that as you may find that you O2 sensour may adjust for that & as to were that leaves it who would know well not me any way as im unsure on how much the O2 sensour on that ECU will adjust i gess the best way then is to try & see unless you can find some one alse thats tryed that & knows
big_boy
Postby Akane » Wed Jan 17, 2007 11:55 am
Compatible injectors are USDM 540cc or Gen 3 3S-GTE 540cc.
You'll need ECU to tune them, or else you won't build boost (1st hand experience.... car just backfires and misfire)
Postby solitaire » Wed Jan 17, 2007 1:17 pm
Thanks guys... perfect :D
solitaire
Postby fivebob » Wed Jan 17, 2007 1:50 pm
big_boy wrote:well thats all fair a nuf then yes the new injectors will run about 125% give or take a bit
O2 sensor will do nothing above about 2500rpm, or 50Kpa. It's only there to adjust idle and off boost low rpms, same as most Toyota ECUs of the vintage. Even then it's won't adjust by much anyway, certainly not enough to compensate for 25% larger injectors
The engine will run way too rich with 540's unless you run an aftermarket ECU, or something like a SAFC which is a VERY bad idea as it will advance the ignition curve to the point of desstruction on a 3S-GTE :(
Postby solitaire » Wed Jan 17, 2007 2:11 pm
Understood... thanks fivebob... ill just get the current 440cc ones cleaned
solitaire
Users browsing this forum: Bing [Bot], Google [Bot] and 17 guests
