Air Con Light Blinking
Postby solitaire » Wed Nov 15, 2006 2:53 pm
Anyone know if the aircon light blinking on a AE92 Levin is a generic error or pointing to something specific?
Only does it on "AC" not on "ECON"
AE92, KZJ120, KDJ120
solitaire
Postby CAMB01 » Wed Nov 15, 2006 7:31 pm
Mine started doing that when it was out of gas, so i just pulled the air con out of the car.
Check the gas
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby matt dunn » Wed Nov 15, 2006 11:28 pm
CAMB01 wrote:Mine started doing that when it was out of gas, so i just pulled the air con out of the car.
Check the gas
Not out of gas but it's when there is a problem with the pump.
There is a pressure pulse or speed sensor in there and if the pump doesnt pump enough it will click out and go into fault mode.
The light will come on for a few sec's then the clutch clicks out and the light flashes?
Postby Alex B » Wed Nov 15, 2006 11:33 pm
Meaning a faulty compressor or magnetic clutch matt?
Postby matt dunn » Wed Nov 15, 2006 11:36 pm
pyro_sniper2002 wrote:Meaning a faulty compressor or magnetic clutch matt?
normally.
or the speed sensor is unplugged or damaged wiring to it.
Belt slip can also cause it.
Postby solitaire » Mon Feb 12, 2007 2:32 pm
Just thought id update this thread with what this error light meant to me in case anyone else ever searches...
On saturday, the day before my wedding :evil: , The air con pump seized... so the levin went home on a tow truck :lol:
So yeah... i know what the flashing light means now.... change the pump :lol:
solitaire
Postby asweetdude » Tue Feb 13, 2007 4:14 pm
Yeah, my GT4 does it too... no noises or seizing of the pump, but apparently the bearings can go in them in which they continue spinning but stop compressing. Common with the compressors too, and theyre an odball compressor on a GT4, so i hope the levin is a common one. a Second had GT4 one costs $200 plus about $500 for the work, gas, consumables etc to fit it.
Anyone know of someone who can do it cheaper?
asweetdude
Postby Bling » Tue Feb 13, 2007 7:50 pm
aircon is overrated :lol:
(I only say that cos aircon in my ae111 doesnt work due to faulty heater unit :evil: )
Postby Boosted_162 » Wed Feb 14, 2007 12:14 am
asweetdude wrote:Yeah, my GT4 does it too... no noises or seizing of the pump, but apparently the bearings can go in them in which they continue spinning but stop compressing. Common with the compressors too, and theyre an odball compressor on a GT4, so i hope the levin is a common one. a Second had GT4 one costs $200 plus about $500 for the work, gas, consumables etc to fit it.
Old cars will generally be expensive to refill, because afaik they have to change the gas with a different kind (R134 instead of R12? They might use a new one now)
Postby solitaire » Wed Feb 14, 2007 9:03 am
Mine got converted by auckland auto air (i think) for $300... that included replacing all the seals... top lads...
solitaire
Postby g-lo » Fri Feb 16, 2007 8:37 pm
i know someone who does aircon repairs
pretty cheap, hes my old mans mechanic,
his name is wayne and his number is
6345400, hes in onehunga
g-lo
