Frontmount intercooler in a ST205
Postby Illusionz » Thu Apr 19, 2007 2:59 pm
Does anyone know how to bascially put in a front mount intercooler into a ST205 Celica, where to run the pipes and mount the intercooler if there is no aircon or Water to air radiators in the way? and any problems i should be looking for before i start?
Illusionz
Postby evil_si » Thu Apr 19, 2007 3:35 pm
the best way is to pull the front apart and basically just work it out,
see what room there, is and the best route for the piping to go.
evil_si
Postby 92mr2paddy » Thu Apr 19, 2007 3:38 pm
yup, take front off see what you have and what you dont. if you dont want to mess around for ages, a complete kit with pipes and joiner and intercooler etc will set you back round 700-800 max (big front mount) imported!
ps if you want details, i can arrange one if needed.
92mr2paddy
Engine light
Postby Illusionz » Thu Apr 19, 2007 7:44 pm
Once you disconnect the i think this the water gauge or something off the intercooler the engine light comes on is there anyway around this?
Illusionz
Postby sergei » Thu Apr 19, 2007 8:07 pm
You will need to hijack IC (can't remember either make it 12v or GND, I think 12v...) wire going to ECU from IC controller.
