but maybe u guys know something the nissan boys don't lol
this is about an 1996 s14 k's PFL
when i got the car, the boost/vacuum lines were all jiggered. well, not in the place they should be. so in the last 2 months me and "the lads" have been messing round with the configuration of them. one day i heard someone with the same BOV as me make the big *WHOOSH* noise..... mine never made that, just had the waste gate flutter. so i investigated, found the line to the BOV was plugged into the wrong place. i then plugged it into the line my boost gauge was plugged into. this is when the issues started.
Then we found this service manual that had a diagram of how the lines are supposed to be, so out we went, hooked them up according to their specifications and that just made things even worse.
now when you accelerate (even like a Nana) its revs fine, boosts fine, changes gear fine, but if you let the revs drop right down to idle they just keep dropping to around 100RPM and some times (getting more frequent) it stalls completely. if it doesn't stall, it drops then bounces back and idles like a good little child.
i have checked all lines and made sure there are no air leaks, checked/cleaned the thing nisbits told me might be the problem and nothing. it sounds like my Blitz BOV stays open too long, but that could just be me.
is there something i have missed? or something i should check???
