What would be best to do as something needs to be done?! Is there a way of pumping fluid back up the drain hole or what. This should have been a 10 minute job which pisses me off
KinLoud wrote:Generally if the bolt is crossthreaded into alloy it will undo fairly easily.
It's unlikely that it has been locktighted but the following will still apply:
If the head of the bolt isn't rounded...
Hit it hard once, square on with a big hammer - this can help to loosen the grip the thread has.
Get a six point socket of the correct size and a long breaker bar.
Make very sure the socket is square on the bolt head.
Undo.
Good luck
ken
ham
021 408 863
Cahuna wrote:I had the exact same problem with the oil filler on my SR20 gearbox, heat was the solution.
frost wrote:my SR20 gearboxpulsar,N14? SR18DE
had the same problem with a nissan diff drain
trend?
