4agte
4agte
Postby Zyros » Wed May 30, 2007 2:36 pm
Hey, just reading up..
What motor would you huys, "personally" recommend for a 4agte project, i was originally going to do a 20v, But no to sure now.
Will a 4agze block, and red-top, smallport head bolt straight up?
If so, i might go with that idea.
Zyros
Postby bluemaumau » Wed May 30, 2007 3:09 pm
ban/
have you used the search function?????????????
Postby scope » Wed May 30, 2007 3:53 pm
this topic has never been covered before
chicken fillet and bacon with everything except onion and bbq, ranch and southwest sauces
current ride: 1980 mazda rx7 series 1
previous rides: ke36 corolla, series 1 rx7, ke30 corolla, ke70 corolla x2
scope
Postby flygt4 » Wed May 30, 2007 6:47 pm
it has been covered, IIRC high comp 4agze from ae101 gtz was the easiest way to make good responsive power. dont ass around with combination engines, simple is better
flygt4
Re: 4agte
Postby matt dunn » Wed May 30, 2007 9:01 pm
There is no answer to that question as it depends entirely on what you are starting with.
You need to answer some things first as it will effect the answer you get.
What car are you starting with, FWD/RWD etc?
What engine is in it now?
How mechanically minded are you?
If the car has a 16V, dont bother with a 20V.
If it has a 20V. dont bother to fit a 16V.
and depending on your
Postby scope » Wed May 30, 2007 9:09 pm
flygt4 wrote:it has been covered
sarcasm
scope
