Tuneing turbo'd ae101
Postby Ollie Wood » Wed May 16, 2007 10:34 pm
just wondering if anyone has tuned after turboing the ae101 and could give me a hand?
Cutting out after about 5pounds?
can you even tuned them??
Ollie 021 1115252
north shore
Ollie Wood
Postby escortman » Wed May 16, 2007 10:50 pm
was it sc b4? or 20v
4x4 toyota blizzard offroader
escortman
Postby ~SlideWays~ » Thu May 17, 2007 10:29 am
escortman wrote:was it sc b4? or 20v
Yeah more info would help.
If running a standard ecu then all you can really do is change spark plug heat range, retard/advance ign timing, up fuel pressure etc.
~SlideWays~
Postby Paulio » Thu May 17, 2007 11:36 am
Dude is there enough gas pumping through to it?
Paulio
Postby evil_si » Thu May 17, 2007 12:43 pm
if it was a 20v before you will need to change the ecu to an after market type, or do a dodgy and trick it from seeing boost.
if it was a gze, something is wrong with your setup
evil_si
Postby Bazda » Thu May 17, 2007 11:05 pm
not_paul_from_waiheke wrote:Dude is there enough gas pumping through to it?
dude havent seen ur car at the drags yet or anything? is it still running?
Postby EVLGTZ » Fri May 18, 2007 12:47 am
yeah man that cars a machine, had like a $20k spent on it...goes hard! psssh psssh!
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
problems
Postby Ollie Wood » Mon May 21, 2007 9:46 pm
yeah is 16v running standard comp, evo 7 pump....
have tinkered with fuel reg (aftermarket), idle's sweet
whats this about spark plug temp????
its got platnum bosh plugs if that matters
Ollie Wood
problems
Postby Ollie Wood » Mon May 21, 2007 9:47 pm
Ollie Wood
Postby bluemaumau » Mon May 21, 2007 9:51 pm
is it a gze?
Postby escortman » Tue May 22, 2007 12:12 am
tell us the what is in it
eg it was a gtz that u converted to turbo etc etc
escortman
Postby The Last Streetfighter » Wed Jun 06, 2007 2:28 pm
AE101 16v could only be 4AGZE or 7AFE.
Postby Crampy » Wed Jun 06, 2007 2:58 pm
Or a 4AFE hehehe.
Crampy
