anyone specialise in 7MGTE wiring?
Postby Soarer T » Thu May 24, 2007 2:00 am
trying to get late model(gray plug) 7mgte wire up to early model mk3 supra(yellow plug). got problem with plug B1(22 pin)and M1(10pin). the 7mgte has more wires in B1 and M1 but earkt model has less wires. just want to know what wire must connect to get the car going.any suggesting would be appriciate.
Soarer T
Postby Jason T » Thu May 24, 2007 9:53 am
http://www.supras.nl/index.php?option=c ... &Itemid=50
I have done this same loom upgrade for me was plug in play needed to adapt power feed to loom only link ID's what is need to run
http://img.photobucket.com/albums/v312/ ... C1Plug.jpg
Spare wire is for extra relay on air con system found not required
Fixing Toyota's since '87
Jason T
Postby Soarer T » Thu May 24, 2007 5:00 pm
thats pretty good infors. cheers m8.
by the way, just had a read today, found that some plug is different fome what i got. refer to pictures.
i am pretty much figured out the B1 and M1 from 7MGE plugs (body). from these two photos, thats all the plug i have got for both 7MGE(body) and 7MGTE (engine), had labeled some plug that i found correctly. how about the rest? from the reading, there is a bit difference for the pin number for the rest of the plug in which i did not figure out.
anyone could tell me what the rest plug refer to?
Soarer T
Postby Soarer T » Thu May 24, 2007 5:03 pm
[quote="Jason T
[/quote]
i think this is a plug "C1", what i have got from the engine is the same plug and wires, but from the body, i got yellow plug exactly the same shape as gray plug and only one wire diferent. ( Blue/white for 7mgte and White/black for 7mge body) how do i wire this ?
Soarer T
Postby Jason T » Thu May 24, 2007 7:27 pm
M1 - Located near the ECU behind the glove box. Handles most signals going to the combination meter
B1 - Located near the ECU behind the glove box. Handles mostly control signals
B2 - Located near the ECU behind the glove box. Handles mostly the ECT signals
B3 - Located near the ECU behind the glove box. Handles mostly the ABS signals
C1 - Located near the fuse box in the engine bay. Delivers the plus signals for the E.F.I. system
U1 - Located at the firewall. Just a connector for the theft deterrent horn, but it is called a connector joining wire harness, anyways.
My car will be back in my hands in a week will take photos of plugs
Getting a little dent buffed out at the mo
Jason T
Postby Soarer T » Thu May 24, 2007 8:04 pm
as my car will be only setup as Manual turbo. so i think there are quite a lot wires i can get rid of (like, TEMS,ABS,ECT, SRS).
well, hopefully you have your car back pretty soon.
Soarer T
Postby Soarer T » Sat Jun 09, 2007 11:52 pm
have found some wires for wire up the fuel pump. but when i test the fuel pump. there is no power coming through the fuel pump relay. dont know what other wires i have to wire up to get it going. hopefully someone had done this before and have some ideas. still waiting for the right answer.
Soarer T
