How do I remove silvertop dizzy?
Postby ChaosAD » Sun Jun 10, 2007 12:10 am
There looks to be only one bolt holding the silvertop dizzy on, but when you remove it you can turn the dizzy but it wont come off. is there a nut inside it? or does it just need a bit more convincing?
and are the bolts that hold a torque convertor onto the crank tha same as flywheel ones? or do I nees a new set?
ChaosAD
Postby sergei » Sun Jun 10, 2007 12:24 am
if you removed bolt and it is moving just use little bit more force it will come out.
Postby Zak » Sun Jun 10, 2007 10:53 am
You'll need a new set of bolts for the fly wheel, as it's quite a bit thicker than the flexi plate.
Zak
Postby flygt4 » Sun Jun 10, 2007 12:52 pm
dizzy should come off easily enuf. i remember i change my cap and rotor a while back, and it onvolved like 1 screw form memory and then popped off
flygt4
Re: How do I remove silvertop dizzy?
Postby thaphatty » Sun Jun 10, 2007 3:58 pm
ChaosAD wrote:and are the bolts that hold a torque convertor onto the crank tha same as flywheel ones? or do I nees a new set?
torque converter isnt attached to crank, backing plate is. and as said, yes you need new bolts. have lost a flywheel before using TC bolts :oops:
thaphatty
Users browsing this forum: Google [Bot] and 27 guests
