been doing alot of searching and all I can find is "20v silvertop ecus won't work on turbo 4ages"
but most of those comments were made 2 or 3 years ago. nowadays its common knowledge that you can turbo bluetops with stock ecu's if you adjust a few things. is this also the case if running a 20v silvertop ecu with AFM? im guessing you would only be able to run low boost though. engine has 4agze internals with raised fuel pressure.
not wanting a massive discussion / arguments, just wanting to know is it a similar process to turboing a stock bluetop ecu? hope this makes sense.
cheers.
