Bluetop 4age flywheel question?
Postby Maxwedge » Wed Jun 13, 2007 2:19 pm
Does a bluetop flywheel (200mm) fit behind a Smallport motor which had a larger flywheel and do I have to change starter motors? Its just that I have a lightened bluetop flywheel that I wish to fit.
Maxwedge
Postby ChaosAD » Wed Jun 13, 2007 4:03 pm
A word of advice, dont use a standard cast flywheel which has been lightened if you value your legs.
But it will fit, you just need to use a matching clutch. The ring gear diameter is the same.
ChaosAD
