BZ-R acceleration?
Postby Lith » Tue Jun 19, 2007 7:42 pm
Mr Revhead wrote:dont be too harsh guys...... there are several possibilities here
I wasn't being harsh, but the amount of time to respond is curious. If I had that kind of power out of a 20v I'd be quite keen to show off my dyno plot.
Lith
Postby Mr Revhead » Tue Jun 19, 2007 9:58 pm
wasnt nessicarily talking to you :wink:
yes it is a long time.....
Postby chindrew » Wed Jun 20, 2007 10:56 pm
thats normal man. You will feel the vvt kicking in around 3500rpm. If you are crusing at around 4000rpm and floor it you will feel the vvt kicking in again at around 5200rpm.
try it out
chindrew
Postby Bling » Thu Jun 21, 2007 12:44 am
could just be that peak torque is around 5200rpm..... vvt never really has a decent kick, its just there and works to make it faster than with no vvt :)
Postby Mr Revhead » Thu Jun 21, 2007 10:24 am
chindrew wrote:thats normal man. You will feel the vvt kicking in around 3500rpm. If you are crusing at around 4000rpm and floor it you will feel the vvt kicking in again at around 5200rpm.
try it out
sorry mate, thats not correct.
VVT doesnt switch on at a set rpm, its tps switched (amoungst other factors)
basicly if the engine is half warm, anything over 1/4 throttle will switch it on.
i guess if you had an aftermarket ecu and set it to switch on at 4000rpm you would feel a kick, as it would be a bit flat untill then
Postby chindrew » Thu Jun 21, 2007 4:39 pm
try it out
Yea i did read somewhere that VVT doesn't work the same way as Vtec for example (i.e. it doesnt kick in at a certain rpm).
BUT I have a 5speed AE111 Trueno with a Blacktop engine and what i've said is from personal experience.
Maybe its just the way i drive
chindrew
Postby slighty_sykotic » Thu Jun 21, 2007 4:54 pm
What your describing is just the way the power/tourque curve is. Nothing to do with the activation of VVT.
And I vote that the orginal poster ethier fronts up with proof, or this whole thread get deleted in tune with the no bullshit policy.
--Sykotic
slighty_sykotic
Postby Mr Revhead » Thu Jun 21, 2007 4:55 pm
fair call.
sunday arvo is deadline
Postby B1NZ » Thu Jun 21, 2007 6:52 pm
In this gys defence, My old AE111 BZ-V seemed to take off at about 5000rpm, seemed to have little or nothing before that so it kinda gave the impression that it kicked in at a certain rpm :wink:
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby Lith » Thu Jun 21, 2007 9:25 pm
However you never claimed >130kw @ wheels ;)
Lith
Postby B1NZ » Fri Jun 22, 2007 8:20 pm
Lith wrote:However you never claimed >130kw @ wheels ;)
no way, mine was more like 180fwkw :lol:
Subaru GF8 Wagon
B1NZ
