unplugging sensors having no effect
Postby l1ttle_d3vil » Sun Jun 24, 2007 5:12 pm
valve clearances on my engine seem fine, so dont think thats whats causing it to be so gutless + foul the plugs. but i've just noticed I can unplug the:
cold start injector
cold start injector sensor/timer
water temp sensor
manifold temp sensor
and none of these effect how the engine runs. I've unplugged them one by one, and also driven the car with all 4 unplugged and it makes no difference at all to how it performs.
do they normally not do much once the engine is warmed up, or is it likely that these sensors are stuffed?
thanks.
Re: unplugging sensors having no effect
Postby big_boy » Sun Jun 24, 2007 8:16 pm
l1ttle_d3vil wrote:cold start injector
water temp sensor
cold start injector & cold start injector sensor/timer these 2 wont do any thing to how it runs
manifold temp sensor this dousent do that much
water temp sensor look at this 1st as it douse the most
for sale EE90
big_boy
Postby ChaosAD » Sun Jun 24, 2007 8:58 pm
Check fault codes,may be in limp home mode or something
ChaosAD
Postby matt dunn » Sun Jun 24, 2007 10:09 pm
as said before the water temp is the only on of those that will have much effect,
but if the water is up to temp when you unplug it, it will go into limp mode and use a substitute warm value so you wont notice a difference anyway.
Unplug it when it's cold and see, but you will need to clear codes afterwards.
Postby ChaosAD » Sun Jun 24, 2007 10:39 pm
Remember there are three water temp sensors, maybe more.
for dash gauge, a/c, fan, ecu etc
ChaosAD
Postby andyztouring » Sun Jun 24, 2007 11:05 pm
Have you checked the cam timing is correct,one tooth out can make it run sluggish,and/or ignition timing.When I say cam timing do the marks and the dots all line up with the marks on the cam backing plate(plate the cam belt covers bolt onto.)
andyztouring
Postby l1ttle_d3vil » Sun Jun 24, 2007 11:15 pm
matt dunn wrote:as said before the water temp is the only on of those that will have much effect,
yep that what I was wondering. timing is all spot on, both cam and spark. compression is also all good (above average if anything). ah well, will keep hunting. or maybe put a turbo on, that'll make it go faster!!!! :lol:
Postby Ae92typeX » Mon Jun 25, 2007 8:14 am
ChaosAD wrote:Check fault codes,may be in limp home mode or something
as suggested, you have checked for codes havnt you?
Ae92typeX
Postby l1ttle_d3vil » Mon Jun 25, 2007 7:35 pm
no I haven't yet, its a bit of a mission as it isn't actually setup with an LED light or anything. will give it a go though and see what I can make out.
