i always thought that you hook it up between the nipple from turbo (going to wastegat actuator) just tee into that and you should get a reading of what the boost/vacuum is.. well that didnt work at all, got no reading and when i drove it to see if it would change i hit fuel boost cut and engine check light came on,, so i must of inetrupted the wastegate or something,,,, if you dont connect it there where does it go???
thanks pat
