hi
hi
Postby EVL20V » Thu Jun 28, 2007 7:45 pm
hi
EVL20V
Postby AceSniper » Thu Jun 28, 2007 8:08 pm
to much fuel? weak spark?
AceSniper
Postby EVL20V » Thu Jun 28, 2007 8:10 pm
yea perhaps a bit of fuel in there, wont try start it for another couple hours yet, took one lead out and sat it on top to see if spark occured when turning over but nothing
EVL20V
Postby Mr Revhead » Thu Jun 28, 2007 8:58 pm
so no spark?
check for a loose wire or something....
the coils on these ar known to fail
checked for error codes?
Postby EVL20V » Thu Jun 28, 2007 9:10 pm
cheers for that, wont be able to get to car till 2morw, the car sounded like on 3 cylinders yesterday then this morning like it was on 2 cylinders :lol:
and was very weak i could have crawled faster. now no life in it at all. will check for spark 2mrw. or coil lead?
EVL20V
Postby 79rolla » Thu Jun 28, 2007 11:06 pm
check both
also check dizzy cap for weair/buld up of crap and oxidation
past: AE82 FXGT
79rolla
Postby EVL20V » Fri Jun 29, 2007 2:14 pm
all leads and plugs sparking good and fuel is geting to it, but wont turn over. and ideas? compression?
EVL20V
Postby sergei » Fri Jun 29, 2007 2:24 pm
check if cams are rotating. Open oil cap and have a look inside when cranking.
If it would not fire because of dirty plugs or bad timing you would have fuel fumes coming out of exhaust.
Postby 79rolla » Fri Jun 29, 2007 7:43 pm
so is it not terning over or not fiering/starting??
if not terning over cheak battery and starter motor
past: AE82 FXGT
79rolla
Postby slighty_sykotic » Fri Jun 29, 2007 7:45 pm
EVL20V wrote:all leads and plugs sparking good and fuel is geting to it, but wont turn over. and ideas? compression?
Seen a few dizzy caps die on those, the centre contact spring shits itself, so you get weak spark to start with, then nothing.
Throw another cap on it.
slighty_sykotic
Postby EVL20V » Fri Jun 29, 2007 9:24 pm
its the coil lead :lol:
tow-started it 2nite and ran like a bag of @#$% for 20secs then freed itself up and then died :cry:
new lead on the shopping list
EVL20V
Users browsing this forum: Bing [Bot] and 16 guests
