there was a few posts from 2004, but availability of all sorts has changed since then
basically what i am wanting to do is create a good tow vehicle that has decent power, plus has the mod cons
initially i thought maybe a commy, but have shied more towards a SUV type arrangement
some discussion went on here about this
now what i was thinking may be the easiest/best way to do it would be to get a 4 door manual petrol v6 hilux surf as a base to start with
some reasons for this:
i want it to be manual
i want 4 doors
i want the option of clicking it into 4wd
i want the widebody version
i want the rear window to be one of the electric roll down ones (and also the other windows to be electric)
i want, i want, i want!!!
id prefer it to have disk brakes all round, id prefer it to not be jacked up suspension - standard height or slightly lowered/stiffened up
questions:
would starting out with a petrol versus a diseasel make things easier - im assuming the petrol tank and lines will be fine to use for the conversion?
would starting out manual make things easier also?
i have read that the v6 boxes work ok with the 1uz, and need an adaptor bellhousing?
ECU-wise, well probably a link also from what i have read?
is there a specific model link that would be best?
would i need a standard ECU if i was going to link it?
im assuming id need a loom for plugs etc and that a cut one would be fine?
engine mounts: assume these all have to be custom?
i asked a question on some guy selling 1uz-hilux mounts on tardme, and he said that surfs used different mounts so they would not fit
does anyone know a link to, or a list of what model/chassis codes would be my best options?
handbrake - now i read somewhere that you have to relocate it to the floor, rather than the firewall. how hard is this to do, and did any surfs come out with a 'floor mounted handbrake'?
which sump would be the best bet?
also links/opinions/prices/hookups would be appreciated for all the other bits and pieces:
fuel pump
clutch
flywheel
motor itself
and anything i may have overlooked (it is 1030pm on a Sunday, i should be asleep
i want to keep it reliable, and fairly factory looking
i imagine a cert on this wouldnt be too much of a drama
thanks in advance for the input!
