Just browsing trademe (as you do
Cheers. Heres a pic to help explain. Bad photo, but you can see the marks on there.
Akane wrote:You know I have a set of JE's which I'd let go for cheap, if you can ever recover them from vvega......
atmosports wrote:If you can go & look at them in person, or get someone you trust to go & look at them. I'd also insist on getting them crack tested or something along those lines before buying also if you can just to make sure. But then it's not really stupid money to buy a new set anyway & it's cheap insurance. Have a good look around the gudgeon bosses as that is the area where JE's generally will fail in turbo applications.
