interesting smokey silvertop
Postby EVL20V » Thu May 17, 2007 1:52 pm
ok well, you floor it and constant blue clouds of smoke pouring out back of car. and fills the cockpit full of blue smoke also 8O
mite need to invest in a full face bio mask :lol: cough cough
are we looking at oil seals and well as rings? wont b 100% sure till we rip it apart, but just so i can get the bits together now. compression pretty much on par
EVL20V
Postby Mr Revhead » Thu May 17, 2007 2:19 pm
bloody hell
havnt poked a hole in the block have you? :lol:
you had a look for leaks? thats a serious amount of oil
if no external leaks, maybe pull valve covers off and see if theres a pile of gunge in the head blocking drain back
Postby EVL20V » Thu May 17, 2007 4:12 pm
oh was i not supossed to drill a hole in from the side into the cyclinder to inspect it? :lol: jokes :lol: it vents to atmosphere yo! :lol:
na will check tomorrow. oh and i noticed a pile of junk sitn on top of gearbox beside exhaust manifold :lol: but wasnt leaking anywhere from memory. hop under car and look up u think?
EVL20V
Postby EVL20V » Sat May 19, 2007 8:06 pm
what can u make from this leak? have taken valve cover off and seems ok, compression 180 each. spark plugs were a little oil soaked, and white tipped. leak looks to be from head gasket region? big puddle of mush ontop of gearbox :lol:
EVL20V
Postby Zak » Sat May 19, 2007 9:42 pm
Dizzy O ring most likely
Zak
Postby vvega » Sat May 19, 2007 9:59 pm
as above
or youve blown out the oil pump gasket
vvega
Postby EVL20V » Sun May 20, 2007 7:16 pm
ok, an update, pulled dizzy off and yes was very oily in one part of the oring and could see a trail where it come from :lol:
unbelievable how much oil is lying on the gearbox :lol: a few $ worth
inspected o-ring, looked ok, refitted and will check again tomorrow. tightened it up good :P
* also, when idling theres a constant faint blue coming from exhaust and you lift the revs up slowly and at about 3k you get a nice flowing cloud of blue :lol: and keep lifting revs you start to choke and annoy the neighbours. so yea not a healthy silvertop. my old rolla engine was worse and found it to have a cracked piston when the new owner rebuilt it :lol: went hard tho
EVL20V
Postby GOLDAE86 » Sun May 20, 2007 8:20 pm
Sounds like an oil control ring to me
To finish first, first you must finish
GOLDAE86
Real Life Mechanic
Postby EVL20V » Wed Jun 06, 2007 1:37 pm
the never ending smokey saga:
did an urgent top up of oil (1L) of 20-40w lol
was in first gear today just coasting at like 2.5rpm and had a constant stream of blue smoke, slowly lifted revs and had a nice trail coming along. good thing i was on a long street and engulfed a good stretch of 50m with smoke cloud that just hovered :lol: when i stopd in the driveway the cabin was full of blue haze and tail pipes were smoking away. gave it foot flat bursts upto 7000 and it spat out a couple little puddles of oily mess :lol: and the smoke was chronic
rebuild? :wink: :wink: 8O
EVL20V
Postby neo » Wed Jun 06, 2007 6:39 pm
You could be lucky and it could be valve stem seals.
Zacs 20v did 400,000 and the valve stem seals were the suspected cause of the smoke.
You can do a pressure test to check if its rings or seals cant you.?.. (not compression test)
neo
Postby EVL20V » Wed Jun 06, 2007 10:12 pm
a leakdown test?
hmm i want to do stem seals, but then have to get a headset (gaskets etc) then i would just want to take pistons out and redo the whole frikn thing :lol:
EVL20V
Postby crispy'86 » Thu Jun 07, 2007 8:00 am
If you've got the right equipment you can replace the stem seals without removing the head., Just need to put the piston on tdc and get a fitting that screws into your spark plug hole and connect an air line to it, this should keep the cylinder full of air and prevent the valve from dropping into the cylinder when you take the valve srings and collets out,
crispy'86
Postby 85AW20v » Mon Jun 11, 2007 10:27 pm
My 20v did the same thing. 3L of oil for 90km's round Manfeild. Pulled it down and found the oil control rings were stuck. New rings and bearings seeing as it was apart and it's all good. Didn't even give it a hone and it's fine.
See ya
Simon
85 MR2 20v
85AW20v
Postby RedMist » Mon Jun 11, 2007 10:38 pm
I'd wonder if excessive blowby is throwing oil into the intake. If you take off the oil cap does it vent pressure? IE Blow at you?
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby EVL20V » Mon Jun 11, 2007 10:51 pm
i could try that tomorrow. i dont have that hose connected to intake also. its now into a catch can.
EVL20V
Postby Mr Revhead » Mon Jun 11, 2007 10:56 pm
theres 2 hoses into the intake
Postby GOLDAE86 » Mon Jun 11, 2007 11:42 pm
EVL20V where abouts do u live id like to take a look at it out of interest.
GOLDAE86
Real Life Mechanic
Postby EVL20V » Sun Jul 08, 2007 2:42 pm
the 2 hoses to the intake have been disconnected :wink:
doesnt blow smoke when idling or when car is cold, once warm you know about it, and yes going down a hill high revs in second at bottom boot it and smoke clouds galore. also, no hissing or sounds coming from under oil cap
EVL20V
Postby rollaholic » Sun Jul 08, 2007 2:54 pm
crispy'86 wrote:If you've got the right equipment you can replace the stem seals without removing the head., Just need to put the piston on tdc and get a fitting that screws into your spark plug hole and connect an air line to it, this should keep the cylinder full of air and prevent the valve from dropping into the cylinder when you take the valve srings and collets out,
or you can fill the cylinder with oil :P
