Anyone ever tried HKS 256 or 264 Cams with a factory ECU or is the MAP signal too inconsistent requiring an after-market ECU like Link?
Intend using on a 4age bigport with TVIS, TRD 0.8 gasket, head skim, TRD bearings, HKS Springs, Fidanza flywheel, HD clutch, ARP studs and bolts. With the intention of transferring Cams to a Smallport at a later date. Intended use is Rallying in an FXGT, the car is ready to rally but has only a standard motor in place but I have a spare bigport which I am playing with, I have purchased most of the parts required and I am investigating camshaft options, without having to switch to a link at this stage.
Your comments appreciated.
