4agze Sensors
4agze Sensors
Postby z0ton » Tue Aug 07, 2007 10:19 pm
Have a couple of plugs that arent being used in my loom and not sure what they are.
Is that the knock sensor? If it is there is no plug that is the same. Do I even need to run it?
And what the hell is this thing on the back of the manifold?
z0ton
Postby l1ttle_d3vil » Tue Aug 07, 2007 10:24 pm
got a pic that shows where they actually are?
the green plug at the back, under the manifold, is the knock sensor. may be in a slightly different position on yours though - maybe further forward.
second pic looks like a water temp sensor or switch of some sort - again, do you have a better pic of where it comes from? does it look like theres been a spade terminal snapped off the end of it or something?
Postby z0ton » Tue Aug 07, 2007 10:39 pm
The 1st sensor is up under the manifold like this:
The other funny sensor is here:
z0ton
Postby bluemaumau » Tue Aug 07, 2007 10:46 pm
$&#$% that first engine looks mint.
yup id agree with little devil
Postby sergei » Tue Aug 07, 2007 10:58 pm
first sensor is knock sensor, second with broken plug is air temp sensor.
Postby themaleman » Tue Aug 07, 2007 11:15 pm
the plug on th knocksensor changes between ae92 and ae101 4agzes, just change plugs if yours is different.
manual 80 series cruiser
4agte ae92 Levin
a15 powered sj410
themaleman
Users browsing this forum: Bing [Bot], Google [Bot] and 8 guests
