Maxwedge wrote:Can you run a smallport head and inlet manifold using bigport loom, injectors, TPS, throttle body etc etc on a bigport block? And if so would you get a power gain?
jondee86 wrote:According to the Club 4AGE spec sheet :
Bigport Max Power 130@6600, Max Torque 15.2@5200
Smallport Max Power 140 @7200, Max Torque 15.0 @6000
So yeah, the smallport has a little more topend power by virtue of the
extra rpm's. If the torque curves are similar, then at 6600 the smallport
is making pretty much exactly the same power as the bigport. So it
doesn't look like the manifold design does much except push the Max
Torque point up the rev range... hm ?
Would this engine be running an O2 sensor ??
Cheers... jondee86
