Restricting boost with no wastegate?
Postby sergei » Fri Aug 24, 2007 12:51 am
Cert for link is bollocks.
They should but more subjective tests for that sort of stuff. Aftermarket ecu is redundant clause anyway since there is power clause (which is hard to prove) and soon to be emission clause.
Oh and how the hell they going to prove if you have chipped ECU? Somebody who wrote VIRM was reading too many ads for chips in the cars. They do not increase power that much anyway.
Take a stock car and put Link ecu, you will have hard time to squeeze power beyond standard level.
As for exhaust, if it exits behind the perimeter of passenger compartment it is not an exhaust leak.
With my car having 2 external wastegates (plumbed back into exhaust), 1x 3" straight through muffler (oval type) and 3" mandrel bent system. I do my wofs in a compliance centre, and I passed a few times (inspected by different inspectors, old and young), the car is very loud under full boost, but when it idling and normal operation it is relatively quiet (although substantially louder than stock). Although these guys do a lot of real race cars (that's where many overseas targa cars are getting NZ WOFs) and are used to diversity, and have nothing against modified cars.
Postby NZ_AE86 » Fri Aug 24, 2007 7:56 am
I agreee that cert for LINK is crazy but the exhaust is a definate fail. The screamer pipe is part of the exhuast system and doesn't exit where it is required to, so this is the difference between what you have and a twin exhuast system that would have both pipes exiting at the rear of the vehicle.
Sergei - no emissions test, they gave that idea up for now.
Current rides;
1985 AE86 Race/Rally Car
1986 Levin GT
NZ_AE86
Postby Guss » Fri Aug 24, 2007 5:29 pm
He now acknowledges that the link and exhaust is o.k but still won't give me a warrant yet as he "has no more stickers" 8O
Guss
Postby deaf_rattle » Fri Aug 24, 2007 8:34 pm
NZ_AE86 wrote:Sergei - no emissions test, they gave that idea up for now.
its very much in the pipe line :wink:
Postby Adamal » Fri Aug 24, 2007 9:46 pm
I remember evil_si was working on a 2JZGTE powered Altezza that had no wastegates on the external size. Instead, he installed a huge wastegate on the intake side between the plenum and the intercooler for controlling the boost.
Postby Guss » Sat Aug 25, 2007 12:13 pm
now i've failed because the lower dash panel is missing :?
anyone have a aw11 dash lower ?
Guss
Postby AE82 FXGT » Sat Aug 25, 2007 3:32 pm
You're freakn kidding?
Does this guy have something against you?
AE82 FXGT
Postby rollaholic » Sat Aug 25, 2007 3:39 pm
Guss wrote:now i've failed because the lower dash panel is missing :?
on what grounds is that a failure? theres not wires hanging down around the pedals are there?
Postby Mr Revhead » Sat Aug 25, 2007 4:25 pm
totally acceptable reason for failing
dash panels can cover sharp/protruding things.
Postby deaf_rattle » Sat Aug 25, 2007 5:26 pm
AE82 FXGT wrote:You're freakn kidding?
as Warwick just pointed out, that is a valid reason. Just failed myself because of the shroud missing around steering column.
Sounds like the wof guy was doin it job. :wink:
Postby Adamal » Sat Aug 25, 2007 5:29 pm
Yea, something like that is for your own safty. I've had a bit of a prod up there and theres some nasty shit on an AW.
Postby Guss » Sun Aug 26, 2007 1:28 am
at first i thought he was being a prick, but yeah he's just doing his job and being reasonable about it although a bit pedantic.
It's for my own safety so i will remove all offending brackets, don't think i'll bother with the surround. and then try my luck again.
His running out of wof stickers seems a little odd though
Guss
Postby NZ_AE86 » Sun Aug 26, 2007 12:21 pm
It has been put aside for now.
Current rides;
1986 Levin GT
NZ_AE86
Postby NZ_AE86 » Sun Aug 26, 2007 12:24 pm
Guss wrote:at first i thought he was being a prick, but yeah he's just doing his job and being reasonable about it although a bit pedantic.
Tell him to just issue the WOF online and not give you a sticker then go to another WOF issuer and ask for a WOF sitcker for your vehicle and they will charge you $7. You should not need to go to this hassle but if you need the WOF the same day then that is one solution. He will have new WOF labels the next day as they are an overnight delivery.
Current rides;
1986 Levin GT
NZ_AE86
