by strx7 » Tue Aug 28, 2007 7:45 am
you cant put an 'early model' 5SFE into it as it doesn't have all the block mounting provisions you require to mount the motor, namely where the hanger bearing/engine mount bolts on, also they dont have a provison for a knock sensor, which your engine will definitily have
Motorsport Bay of Plenty -
http://www.mbop.org.nz
