20v Supercharged.
20v Supercharged.
Postby trdtrueno » Mon Sep 10, 2007 11:08 am
Hi everyone i was wondering what i would need if i decided to add a supercharger onto my 20v. what parts will i need and things like that.
also does anyone know how to take the rocker cover off, as i want to paint my one a different colour??? sorry, but im not much of a mechanic but willing to try.
any help appreciated
trdtrueno
Postby pc » Mon Sep 10, 2007 12:49 pm
If you have to ask how to take a rocker cover off, then superchaging will be too hard for you.
You will have to pay someone to do it for you, be prepared to spend many $1000s
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby bluemaumau » Mon Sep 10, 2007 5:13 pm
:lol:
Postby trdtrueno » Mon Sep 10, 2007 8:39 pm
actually did it today......didnt take long. so anyone know wats involved with supercharging a 20v?? would it be quicker than the stock 4AGZE???
trdtrueno
Postby bluemaumau » Mon Sep 10, 2007 8:54 pm
yea, but itll cost you a whole heap more, because youd want a aftermarket ecu to run it
Postby Zak » Mon Sep 10, 2007 9:44 pm
I have a Supercharged 20V, it makes 145KW at the wheels, so it's pretty quick I suppose.
I can help out a little, but it will cost you alot to build.
Zak
Postby 20v_rollaboy » Mon Sep 10, 2007 10:23 pm
Hey Mr Zak, do you have any close up pics of your setup? Do you still run quad throttles? And what charger are you using? Cheers
20v_rollaboy
Postby 20v_rollaboy » Mon Sep 10, 2007 10:37 pm
Sorry, just clicked on your signature :P Any reason you decided to ditch the quad throttles? Was it to run the ecu?
20v_rollaboy
Postby Adamal » Mon Sep 10, 2007 10:51 pm
S/C engines like th throttle body before the S/C :)
Postby trdtrueno » Mon Sep 10, 2007 11:21 pm
would it be cheaper to turbo or this?? coz im pretty keen
trdtrueno
Postby matt dunn » Mon Sep 10, 2007 11:40 pm
trdtrueno wrote:would it be cheaper to turbo or this?? coz im pretty keen
Turbo 20V will be
easier
+ cheaper
+ more power
than a Supercharged 20V
Postby 20v_rollaboy » Tue Sep 11, 2007 12:40 am
Adamal wrote:S/C engines like th throttle body before the S/C :)
What would be the disadvantages of running charger before throttle?
Air into Charger - Charger to intercooler - intercooler to intake/quads.
Taking into consideration there would have to be some way to relieve pressure when the throttles are closed.
20v_rollaboy
Postby escortman » Tue Sep 11, 2007 7:40 am
how much do u have to spend?
4x4 toyota blizzard offroader
escortman
Postby barryogen » Tue Sep 11, 2007 11:47 am
20v_rollaboy wrote:What would be the disadvantages of running charger before throttle?
none... it is a much better way of doing it, you get to keep steller throttle response, but it is usually a bit trickier to setup apparently. can't see why though.
barryogen
2ZZ Guru in training
Postby Zak » Tue Sep 11, 2007 7:31 pm
20v_rollaboy wrote:Hey Mr Zak, do you have any close up pics of your setup? Do you still run quad throttles? And what charger are you using? Cheers
Click the link in the sig below
Zak
Postby trdtrueno » Wed Sep 12, 2007 8:35 pm
ive got about 2k atm, but will have more money as i start workin over the holidays
trdtrueno
Postby escortman » Wed Sep 12, 2007 9:21 pm
thats about enuf for a link tuned and installed, u stil need to buy supercharger and all associated items intercooler, piping, pulleys etc. wat internals are u going to use or just using stock 1s?
escortman
Postby Zak » Wed Sep 12, 2007 9:29 pm
Stocks fine, just pump in plenty of fuel and back off the timing a bit.
Zak
