hks blow off valve?? found problem
Postby B-style » Sun Sep 02, 2007 9:33 pm
I recently got a genuine hks ssqv bov to replace my standard skyline one.
but as I went to fit it I noticed that the valve doesn't have any spring tention to keep it closed. You can press the valve open with a finger and it'll stay open. thought this was very strange, but being a pull type i thought I'd try it anyway. and it seems to work fine!
any help would be appreciated
brent
1997 honda integra type r
1992 toyota levin gt-z turbo
B-style
Postby matt dunn » Sun Sep 02, 2007 9:55 pm
Us and a few others have had trouble with the HKS ssqv type at high boost levels, they just would not keep the pressure in.
Binned them in the end and went for most basic designs.
They seem ok for road car and low boost levels though, ( less than 16 psi or so)
Postby fivebob » Sun Sep 02, 2007 9:59 pm
matt dunn wrote:Us and a few others have had trouble with the HKS ssqv type at high boost levels, they just would not keep the pressure in.
Genuine HKS or a cheap copy?
Never heard of genuine ones giving a problem even at 30PSI. Copies though always seem to give problems, even at low boost levels :evil:
Postby matt dunn » Sun Sep 02, 2007 10:04 pm
I am pretty sure that they were geniune as I remember them going on about how much it cost and how it diddn't work.
Took quite a while to suss out why the boost would not go above 17 psi.
I had a similar issue with my own one which was a turbo smart one.Pulled it apart and fitted about 8mm of washers under the spring for more tension and it was amazing how much faster it came on boost.
maybe the HKS one's we tried were just dud ones?
Postby TRD_ZERO » Sun Sep 02, 2007 10:25 pm
Ive heard they do leak over say 20psi, but ive had one brand new out the box and even the hks sqv which is the one before.Ive taken them all apart i just dnt see how they would leak as pressure forces them closed due to their design rather than the other ones that get pushed open by pressure.
TRD_ZERO
Postby B-style » Sun Sep 02, 2007 10:30 pm
the strange thing is its not leaking but i'm plaing on running 18psi in the near feature.
but do you guys know if they are meant to have tention on the valve?
B-style
Postby TRD_ZERO » Sun Sep 02, 2007 10:42 pm
Yes there should be a spring inside if you press the little green knob it should spring back. Take it apart and have a look to see if there is a spring inside.
TRD_ZERO
Postby evil_si » Sun Sep 02, 2007 11:22 pm
with the hks ones ive only had trouble with them at low boost in the past,
the 2 on my rx7 seem ok at 8psi, havent upped the boost to 20 yet so not sure how they will respond
evil_si
Postby B-style » Sun Sep 02, 2007 11:31 pm
yeah took it apart the other day quickly, but only took off the shroud and front cover. should there be a spring in the back piece?
B-style
Postby B-style » Thu Sep 06, 2007 12:15 am
well took it apart, and for some reason there is no spring at all!!!
so don't know where i'm going to find one!
B-style
Postby stalker » Thu Sep 06, 2007 12:32 am
I had a HKS bov in an old car (wow, that was 6 years ago now) and it crapped itself one day...so i went to the local perf shop who stocked hks parts and they said that they are common for not working...the spring inside loses all tension.
even hks themselves knows that this happens, cause they have a hole parts list of just springs for the bov's.
:lol:
so yea, just go to hks or hks surplier and get a new spring.
AE85.6 Levin - Project car Click Here
RZ Supra formully known as EMZ RZ
stalker
Postby B-style » Thu Sep 06, 2007 8:02 pm
i went into red line performance (hks agent) today and apparently they don't do them at all.
they suggested that i'd get one made up.
B-style
Postby stalker » Thu Sep 06, 2007 10:54 pm
B-style wrote:i went into red line performance (hks agent) today and apparently they don't do them at all.
really?? garbar!
i know it was like 6 plus years ago since i got my spring...ummm, ill see what i can find out for ya. my flatmate is having the same problem atm, so if we find something out ill let ya kno.
(tried to see what springs are for sale on TM?)
stalker
Postby 92mr2paddy » Fri Sep 07, 2007 7:57 am
chuck the hks away if your having problems! if you have to replace the spring now you will probly have to do it again some time in the future. what a hassle! get a GFB, everyone i know thats got one says they work mint, never leak pressure even at 20psi, i have one and there are absolutely no problems
92mr2paddy
Postby Bumpy » Fri Sep 14, 2007 6:10 pm
I'm sure mine is an HKS copy, and I've never had any problems. Run 12psi for prob 4 of the 5 years i've had it.
Bumpy
