ChaosAD wrote:Dont see why they wont work as its the same principle as a turbo engine
Zak wrote:The blow off valve will be identical to a waste gate, just one was made for high exhaust temps. Having your boost venting like you want will make one hell of a noise, mine is bad enough in 10sec spurts let alone any time your not on boost.
If you weren't so far away I'd show you what it's like, but it's bloody loud.
Zak wrote:That might work, plumbed back in it will be quiter, but you'll still hear it thats for sure.
Zak wrote:It's the only think I don't like about it, is that it's on or off, you can't make a small amount of boost like on a turbo. At least with a toyota charger.
sergei wrote:what about using scooter gear to drive it ;) crazy idea but modified CVT from a scooter will be perfect for supercharger (no drive at idle, and max rpm of supercharger independent from engine) sound good....
