How to decode ae111 codes (bz-r bz-g etc)
Postby Mr Revhead » Mon Mar 21, 2005 1:03 am
yup pyro and TRDWGN are correct.
or its had a replacement box
Postby Paolo 20v » Tue Jul 26, 2005 4:45 am
Damn mates, you know quite a bit about codes!!! There is so much I didn't knew, thanks!!! :) 3 questions: 1)so if I'm reading correctly, if a Trans/Axle says for example: C-56/04C it means it comes factory with LSD?? A friend has a 1995 Levin BZ-G with those specs. 2): that LSD you guys where talking about before, that comes factory in BZ-Rs, is it 2way, 1.5way, 1way... or what?? 3)What does "TRIM" means on the VIN Nº and how do you decode it?? Thanks bros :)
Paolo 20v
Paolo 20v
Postby Mr Revhead » Tue Jul 26, 2005 10:10 am
it helps when i work at toyota and have the EPC.
A: then it would appear to have a factory lsd.
B: its none of them, its a torsen type
C: trim is the interior colour/spec. id have to go through the EPC to decode it
Postby sergei » Tue Jul 26, 2005 8:08 pm
EDIT: Redundant question removed.
Postby Mr Revhead » Tue Jul 26, 2005 8:12 pm
torsen
Postby Alex B » Tue Jul 26, 2005 8:54 pm
Trim FR30 :D ???
Postby Paolo 20v » Fri Jul 29, 2005 5:24 pm
Thanks MrRevhead, all the info is very much appreciated! If you happen to have near you the TRIM decoding data, it would be awesome also! Thx bro :wink:
Paolo 20v
Paolo 20v
Postby Santa'sBoostinSleigh » Thu Jan 12, 2006 3:38 pm
Warwick, just another 'you are wrong post':
my 1995 BZG wreck has a LSD manual 5speed gearbox :P
as stated by the build plate with a big fat C on the end
also tested via the burnouts in the garage method
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby Mr Revhead » Thu Jan 12, 2006 3:41 pm
wanna get me the full model and frame numbers?
Postby Santa'sBoostinSleigh » Thu Jan 12, 2006 3:50 pm
Mr Revhead wrote:wanna get me the full model and frame numbers?
bah ive given them to you ages ago!!
will have a look and get back to you - info is all at home and im not!
but i do remember that it all matched with: http://english.auto.vl.ru/catalog/toyot ... 95_5/2961/
hence:
E-AE111-ACMZF
and the build plate definitely says C-56(?)/XXC
superstrut model
note that the non SS model says it has no LSD in auto.vl.ru
Santa's Mega Sale
Postby Mr Revhead » Thu Jan 12, 2006 4:10 pm
i think S/S may be the key..... get me that frame number and ill do some more digging.
i think iv seen something......
Postby Mr Revhead » Fri Jan 13, 2006 11:23 am
ok dunno if i nver saw it before or if its been added on an update but if you have a preface lift BZ-G with superstrut itll have an LSD box.
the facelift BZ-G however is non lsd.
im gunna get my hands on one of these boxes these days and open on up.... iv decieded im unsure if they are helical or viscous type :?
Postby sergei » Wed Jul 04, 2007 12:24 pm
Some correction: BZ-Rs have Torsen LSD.
http://en.wikipedia.org/wiki/Torsen
(http://www.torsen.com)
As far as I could see when I pulled apart m gearbox, the Torsen in BZ-R box is Type 2.
http://www.torsen.com/products/T-2.htm
Postby Mr Revhead » Wed Jul 04, 2007 12:39 pm
yes correct, at the time of writing that id been told different, as i hadnt seen inside one myself.
edited the above 8)
Postby AE111Bob » Wed Oct 10, 2007 4:29 am
Thats some great information there fella! Nice one!
As there is little info on AE101/111 in the UK i am finding myself reading through NZ forums and are all very useful!
One question though, I have a BZG prefacelift without superstrut or an LSD, but i want to fit an LSD.
Will an LSD out of a 5/6 speed with or without superstrut fit?? Or is the driveshaft splines different??
I know the 6 speed has a different ratio final drive, but its easy enough to swap over a crown wheel (ring gear) so long as the unit will fit in my casing and the driveshafts will work.
Thanks people
Bob
AE111Bob
