Wastegate Actuator Question
Postby MrOizo » Sun Oct 14, 2007 9:44 pm
I got with my JZA70 a aftermarket turbo installed and i am wondering what the deal is with it having 2 vacuum/boost feeds. At the moment it is just tee-ed and connects normally to a air supply.
Is it for some sort of boost control?
Pretty much like this one:
Cheers.
MrOizo
Toyspeed Legend
Postby method » Sun Oct 14, 2007 11:23 pm
Yeah, you connect them both up and bleed the bottom one (off the top of my head). Will let you get higher boost pressures more reliably that just bleeding the main one.
A lot of the time the second port isnt even sealed though.
PICS UPDATED DAILY
method
Postby MrOizo » Mon Oct 15, 2007 7:18 pm
How does that work? The way i'm reading your post is there is 3 connections :?
Connect the top one up and bleed the bottom?
MrOizo
Toyspeed Legend
Postby MrOizo » Thu Oct 18, 2007 3:16 pm
Anyone have views on this ? :?
MrOizo
Toyspeed Legend
