AE86 slave cylinder question.
Postby HachirokuGTV » Sat Oct 27, 2007 8:04 am
I was installing a new slave cylinder yesterday but it didnt have the small arm or rod that pushes the clutch fork. Do they normally come with the slave cylinder or do I need to get one from Toyota?
HachirokuGTV
Postby Rick » Sat Oct 27, 2007 9:20 am
All the non toyota slave cylinders I have bought have had the rods included, you could grab one from Pick a Part.
Postby frost » Sat Oct 27, 2007 4:32 pm
the ones i got from bnt didnt come with the rod, i asked them if it was ment to include it and they said "no your ment to use your own one because its quite a common slave cly and the other cars dont use the same length rod but5 same cly.
Postby HachirokuGTV » Sat Oct 27, 2007 4:48 pm
That sucks cos my car is an AE85 and hence ive never had one.
HachirokuGTV
Postby matt dunn » Sat Oct 27, 2007 6:14 pm
frost wrote:the ones i got from bnt didnt come with the rod, i asked them if it was ment to include it and they said "no your ment to use your own one because its quite a common slave cly and the other cars dont use the same length rod but5 same cly.
The one I bought from BNT definatly had one as that was the whole reason I bought a new one, becasue the original one went missing.
Although I dont know if it was a T50 on I use, it may be for a w W series box.
Postby d1 mule » Sun Oct 28, 2007 2:59 am
mine from BNT didnt have one i remember cuz i worked there when i brought it, i raped one from a ae92 i think, worked a treat was like 5 buckas from jus toymota
d1 mule
Postby frost » Sun Oct 28, 2007 9:13 pm
LOL^^^theres your answer, someone at bnt is taking the rods for there own,
Postby mr30%jr » Sun Oct 28, 2007 9:57 pm
answer hoard slave and master cylinders :lol:
alternativelty you can hone it out and put a new oring on the piston for about 1dollar and 20mins work
mr30%jr
