Airbag light
Airbag light
Postby BzzzzR » Wed Oct 24, 2007 8:39 pm
Hi all
I seem to have a wee issue with my airbag warning light ..I got a little road rage and gave the horn a thump and now the airbag light comes on from time to time ..Its strange on first start up of the day no light but on 2nd etc the light is on ,I have tried disconnecting (sp) the battery with no luck..Warrant is due soon and dont want to fork out too much $ ..any thoughts??
BzzzzzzzzR
BzzzzR
Postby thegreatestben » Wed Oct 24, 2007 9:18 pm
take the bulb out of your dash cluster
thegreatestben
Postby Adydas » Wed Oct 24, 2007 9:26 pm
Great advise above, Very helpfull..
Sounds like you have a serious case on your hands, could mean you have to replace the airbag unit inorder to keep a WOF, you seem to allready be aware of the fact that with that failing your WOF is seriously on the cards.
My suggestion would be take it to Toyota and talk to them about checking it out, resetting it and hopeiung its allright.
Adydas
Postby rollaholic » Wed Oct 24, 2007 10:21 pm
dont mess around taking the bulb out, you'll still fail a WOF if the inspector is even half awake.
just get it fixed, do you really want a (possibly) faulty air bag aimed at your head?
Postby Jdawg » Thu Oct 25, 2007 2:48 am
Arms, the gas burns your arms. Only hurt your head if you nod off
Jdawg
Postby rollaholic » Thu Oct 25, 2007 7:07 am
figure of speech :P
Postby BzzzzR » Thu Oct 25, 2007 8:34 pm
cheers guys ..yeah I know it will fail a warrant just wanted to know if it was a common fault will take it to toyota next week ...I will most likely just get a after market wheel and cert if I cant sort it
BzzzzzzzzR
BzzzzR
Postby gepsk8 » Thu Oct 25, 2007 9:21 pm
autosparky ur best bet, probably cheaper to.
O272754663
gepsk8
Postby Zak » Thu Oct 25, 2007 10:08 pm
Most likely the airbag ecu, it's about $700 odd off the top of my head, quite comon on the ae111's (I'm assuming thats what you have)
Zak
Postby matt dunn » Fri Oct 26, 2007 12:51 am
gepsk8 wrote:autosparky ur best bet, probably cheaper to.
Yeah,
we do Airbag stuff at work all the time.
Just go to a firm that has a scan tool to read codes or they will end up getting it done as outwork anyway.
Postby rollaholic » Fri Oct 26, 2007 6:44 am
BzzzzR wrote:I will most likely just get a after market wheel and cert if I cant sort it
good luck with that :D
Postby BzzzzR » Fri Oct 26, 2007 6:13 pm
I assume that it is ok to get A/M wheel and get it certed ? I have done a wee phone around and first stop is toyota to see if there is any error codes then perhaps a autosparky and yes it is a 98 ae11 bzr
thanks for all the replies
BzzzzzzzzR
BzzzzR
Postby rollaholic » Fri Oct 26, 2007 6:18 pm
i believe the only legal way to get away with no airbag is to turn it into a race car - ie full roll cage, log book, etc etc
Postby Adydas » Fri Oct 26, 2007 6:37 pm
yeah, you cant just remove the airbag from the car and put a momo wheel on it.. If it has an airbag standard its going to need one to continue getting wofs on nz roads..
Adydas
Postby Mr Revhead » Fri Oct 26, 2007 10:28 pm
only non race car i know of having it done was a prado, that was often used off road and had rather heavy duty bull bars and undertrays.
i doubt it would pass these days
Postby Caribeena » Fri Oct 26, 2007 10:45 pm
i got quoted $650 from toyota, but ended up finding a wrecker that gets them in new for $300
my light used to come on, got the codes checked and ended up being the ecu.
Caribeena
Postby Lloyd » Sat Oct 27, 2007 9:44 am
You can get the airbagg removed and certed as such. You'll need to remove any sign that it had an airbag fitted or put big labels in the car saying airbag is removed. Look at the vehicle interior section of the VIRM on page 7-6-1
Postby xsspeed » Tue Oct 30, 2007 11:16 am
go to a sparky you trust, a lot of the time the problem is because a fuse that provides backup source to the airbag has gone. In my old falcon the fuse for the rear lights went and this as it happenned ws the backup source for the airbag so the light came on. Your best bet is to go to a sparky and get it scanned, but get them to explain what the error code is before they do the work. That way you may be able to avoid a costly ecu replacement, if the problem is just the fuse.
ost sparkys are all good, but theres a guy down the road from me i dont go to anymore after he tried to take me for a ride on price.
Postby Zak » Tue Oct 30, 2007 9:36 pm
It's the actual ecu that craps out, it's very common on the ae111's. Hence why the ecus are so cheap. Most are $1000+ new.
Zak
