Strut top hat removal
Postby big-ben-007 » Tue Oct 30, 2007 3:48 pm
Basiclly I brought some TRD lowering springs off Mr.Rev (thanks btw)
Got the left rear strut off and proceded to take the top hat off......
Now I know I've got to compress the springs etc. done all that but the actual nut to get the top hat off is being a bit of a pain.
When I turn it, it turns the shaft, thats why the shaft usually has a flatspot for vice-grips or some other thing to hold it to clap onto, the only flatspot I can see/find on my strut is at the end of the thread right by the end nut and its so small nothing we have is small enough to be able to get enough of a grip to stop the shaft from moving when I try and loosen the nut
Any suggestion would be helpful :D
PS: The car is a 91' Ae101 Levin GTZ Superstrut
Now: 1956 Dodge Pick-up, 1988 EP71 Starlet
Before: 1985 Ford Telstar, 1989 Mazda 323, 1991 Ford Telstar s/w, 1991 Nissan Pulsar GTI, 1991 R32 Nissan Skyline RB20DE, 1991 AE101 Levin GTZ Superstrut Version
"Oh man, I just shot Marvin in the face" - Vincent Vega
big-ben-007
Postby 2LTR Rona » Tue Oct 30, 2007 3:55 pm
loosening it a bit BEFORE you remove the strut from the car is usually the way to go, then its a piece of cake one out :wink:
But that doesn't help this situation.....
You will have to try and relocate the shock shaft back in to the top hat, there is a notched out portion that will line up and then proceed to remove the nut.
If you have an impact gun & socket handy it makes this job a piece of cake.
2002 Altezza, 1974 KE25
2LTR Rona
Postby big-ben-007 » Tue Oct 30, 2007 4:01 pm
Hmm I may just chuck it back in the car with 1 bolt at the bottom, two at the top at try and loosen from there, if not I'll go down to dads work and 'borrow' a rattle gun :lol:
big-ben-007
Postby Distrb » Tue Oct 30, 2007 4:22 pm
other option i've used on occasion is use some vice grips wound up as tight as you can on the shock shaft. Just make sure you wrap a reasonable cloth round the shock shaft so you dont damage it with the vice grips.
the nut might be a little tight for this method though
Distrb
Regular Poster
Postby bbq1988 » Tue Oct 30, 2007 4:22 pm
We gave mine a tap with a rubber mallet, worked a treat
Baked, Not Fried.
bbq1988
Postby big-ben-007 » Tue Oct 30, 2007 4:42 pm
Just partially bolted the strut back in and loosend the nut and off she came off easier than a drunk girls pants at her 18th :lol:
Thanks to all :D
big-ben-007
Postby frost » Tue Oct 30, 2007 4:43 pm
rattle gun is the best/easiest if you have access to one
Postby ChaosAD » Tue Oct 30, 2007 5:06 pm
Just dont use the rattle gun on adjustable shocks such as koni.
ChaosAD
Postby Cakky » Tue Oct 30, 2007 8:04 pm
yeah, done mine last night, pretty easy if you use a rattle gun, but you seem to have it figured, my right bumpstop was in a hundred pieces haha, bit of a pita at 8.00pm at night when you can't really go buy a new one and you gotta get your car outta your mates garage hahaha
Cakky
Postby Mr Revhead » Tue Oct 30, 2007 8:40 pm
remember for the next time, loosen first :wink:
by far the easisest option! if you dont have air tools
Postby big-ben-007 » Tue Oct 30, 2007 9:24 pm
My hast to get my car low cost me as I couldnt get it done before work :oops:
Oh well
big-ben-007
Postby Cakky » Wed Oct 31, 2007 6:11 pm
just replaced my bumpstops and boots, broke a stud on the top hat *punches self in head* what a nightmare..
Cakky
