1jz gte jza70
1jz gte jza70
Postby MRDRFT » Sun Nov 04, 2007 2:54 pm
do they have factory oil coolers?if so where are they located?
thanks Brad
1992 toyota supra 1JZ power
210kw atw on 12psi
1999 nissan silvia drift car,
223kw atw on 12psi
MRDRFT
Postby Py7h0n » Sun Nov 04, 2007 8:01 pm
yup....
on the block... it is what the filter screws onto
Py7h0n
Postby d1 mule » Sun Nov 04, 2007 8:08 pm
it wont be the typical "front mount" styly that you will be thinking of they are a cylinderical thing between the block and oil filter that cool water folws through. bad idea really as if either your oil or water get excessivly hot the other will too
d1 mule
