AE101 GTZ Fuel consuption
Postby 20v FX-GT » Mon Nov 05, 2007 10:34 am
Hi All,
My first post on Toyspeed in about 2 years!
My GF has a AE101 GTZ with a couple of minor mods - pod filter, big exhaust and headers. It seems to get through petrol like its going out of fashion. She doesn't know any different but compared to my AE111 20v its a huge difference. The most we can get out of a tank is 400km on the open road (using 95/98 by the way). In comparision my 20v can get 600+ on the same roads same driver, same speed, etc.
I've changed the oil and plugs. Is there anything in particular on a 4agze that causes it to use a lot of fuel or is it just the nature of the beast?
Matt
1981 & 1982 MK1 VW Golf GTI 8v
1997 AE111 Toyota Trueno 6 Speed
My profile l AE101 FX GT Site l AE111 BZ Site l
20v FX-GT
Postby Leon » Mon Nov 05, 2007 11:18 am
The best fuel economy I've managed out of the 4AGZE MR2 is 11km/l. Typically it is 9-10km/l though, just seems to be a thirsty car.
Postby MrOizo » Mon Nov 05, 2007 11:30 am
Have a go at checking the codes and see if that shows up anything.
Doesnt the knock sensor throw the timing out and all that - would that use more fuel?
MrOizo
Toyspeed Legend
Postby 20v FX-GT » Mon Nov 05, 2007 11:46 am
MrOizo wrote:Have a go at checking the codes and see if that shows up anything.
How do I check the codes? Do I need a diagnistic tool or is there a way of making lights flash on the dash?
20v FX-GT
Postby Distrb » Mon Nov 05, 2007 11:49 am
does the car heat up to normal operating temp?
i had a similar issue with my ae92 gtz as it didnt quite get up to operating temperature, so used to run almost constantly on cold start.. with super poor fuel economy. Replaced thermostat (and radiator, as it was in a bad way) and that fixed it.
Distrb
Regular Poster
Postby 20v FX-GT » Mon Nov 05, 2007 12:01 pm
Distrb wrote:does the car heat up to normal operating temp?
Hey Andrew,
Long time no hear, how's things?
Yes, it heats up normally - water temp sits at about half way on the guage.
20v FX-GT
Postby CAMB01 » Mon Nov 05, 2007 6:36 pm
My old FX with 4agze conversion would get 500km from a tank around town, and over 600km on the open road.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby KinLoud » Mon Nov 05, 2007 10:44 pm
Yeah - I got about 500kms to a tank in my old AE101 GTZ, pretty much the same as my 20v Marino
Ken
Ham
021 408 863
Postby Leon » Tue Nov 06, 2007 8:36 am
How many litres did it take when you filled it?
My MR2 reads empty at 300k, but then barely takes 30 litres.
Postby 20v FX-GT » Tue Nov 06, 2007 8:48 am
Over 40 litres.
20v FX-GT
Postby Scrunty » Tue Nov 06, 2007 11:04 am
Leon wrote:How many litres did it take when you filled it?
Same here, but then we only get a 41L tank :lol:
SW20 g4 n/a
Scrunty
Postby pjay » Tue Nov 06, 2007 12:27 pm
500km to a tank.. tank = $60-70 dollars
pjay
Postby pidge » Tue Nov 06, 2007 1:16 pm
On the open road I can get up to just on 12km/L, strictly around town drops to around 10km/L or maybe a bit lower.
Also check that the tyre pressures are correct.
pidge
