Installing Turbosmart Pneumatic Fuel Cut Defender On ST185
Postby Al » Thu Nov 15, 2007 6:19 pm
dvmv_kim wrote:so your telling me i spent $200 for nothing when i can just block that pipe..
Yep. Awesome eh?
Al
Postby dvmv_kim » Thu Nov 15, 2007 6:28 pm
flygt4 wrote:yes.
and you will see variations in boost pressure dependant on load on the engine/gear you are in.
so its normal?
dvmv_kim
Yep. Awesome eh?
haha sh!t yeah!
dvmv_kim
Postby flygt4 » Thu Nov 15, 2007 7:48 pm
dvmv_kim wrote:
flygt4 wrote:yes.
so its normal?
i used an elctronic hks one in my old gt4 , as i still wanted to retain a boost cut of some kind. i raised it to 17psi so i had a backup. i would see 12-13psi in 1st and 2nd, and 14-16psi in 3rd-5th
flygt4
Postby dvmv_kim » Thu Nov 15, 2007 8:12 pm
did ur car last with that much psi running in those gears cause that sounds like what my car is doing
dvmv_kim
Postby flygt4 » Thu Nov 15, 2007 8:22 pm
yeah went for over a year like that although it destroyed typical clutches and gearboxes.
ive known a few other people start smoking out their ct26's in short time at 15psi tho :lol:
flygt4
Postby AJz » Thu Nov 15, 2007 8:27 pm
hehe, yea pretty much, sorry
I had vtax :(
AJz
Postby dvmv_kim » Thu Nov 15, 2007 8:31 pm
argh will that sucks.
dvmv_kim
Postby Boosted_162 » Thu Nov 15, 2007 8:36 pm
Oh the joys of a facelift ST185, 17psi boost cut for me :D
Will be higher with the Blitz ECU :wink:
Postby ChaosAD » Thu Nov 15, 2007 8:37 pm
Would pay to throw your car on a dyno and check afr's after playing with the boost
ChaosAD
Postby dvmv_kim » Fri Nov 16, 2007 12:36 am
wheres the dyno place or is it just speedtech? cause i got told there a rip
dvmv_kim
Postby ChaosAD » Fri Nov 16, 2007 6:44 am
Theres a lot of places around with dyno's.
Generally for a power run its about $50 for a 2wd or $100 for a 4wd.
Its worth it for piece of mind though.
ChaosAD
Postby Akane » Fri Nov 16, 2007 10:40 am
Don't worry, we've all gone through that stage before. You'll get wiser once you owned a 3S-GTE.
