by KinLoud » Tue Nov 27, 2007 9:37 pm
Disk brake calipers needs higher pressure to get the same braking force.
A drum brake proportion valve will give a lower pressure to the rear when compared to a disk proportion valve.
You will have no problem with rear brake locking.
However - your overall braking will be better if you can find a disk proportion valve.
Hope this helps
Ken
Ham
021 408 863
