Hey, Well i'm considering this swap - makes so much sense! What info is available about engine mount points and differences? I've got a rear sump 1JZ-GTE which shouldn't cause any problems with the GA70 crossmember - not as far as I can tell anyway. Just wanna know if anyone knows of an adaptor or anything for 1G to 1J mounts... Or any other useful info for that matter! Chur
Ah yes! But unfortunatly not - My car is a 1992 however has a 1986 crossmember in it! Still I should be able to sort something out with that, Cheers boe!
