Caveman wrote:Do you have the tps wired correctly? Sounds like you may be grounding the vcc (sometimes just called vc) wire on accident.
Likewise with bazda 4agze ecu should take na tps fine, speaking from my old car.
escortman wrote:does any1 have a tb with sensor on that i could try on my car to see if that changes it?
