since I've got my aw11 ('89 nz new) mr2 I've found the level on the header tank (when cold) will go down about a centimeter or so after each use. When it was nearly empty and the engine hadn't been run for a few hours i filled it all the way up, I've done about ~120k since then and the level on the header tank went down to around 2/3 full, so it definitely uses a little bit of coolant which seems a bit worrying.
the 4age has just clicked over 288,000ks and it has red cam covering lettering with t-vis.
did a compression test after letting the car sit cold for a few hours, results here:
cylinders
1 - 195psi
2 - 193~
3 - 205
4 - 205
the oil filler cap has no brown or murky shit inside it and i opened up the radiator cap and let it idle for a bit, no bubbles (well shit they would've been pretty obvious i guess haha) so i doubt the headgaskets gone.
there is a shitload of water pipes in the aw though..i don't see in the front or round the engine that are obviously leaking, so i'm kinda stuck here trying to figure out why it's using water :s don't think you're meant to need to fill up the tank each time you get etrol, so it can't be normal, right
any help would be appreciated,
thanks,
jono
