need to no as i snaped my tierod and i would rather get good ones than shit ones,
thanks
postfach wrote:if the a70 supra has the same lock as the z20 soarer, you don't need any more lock, it's fine how it is
Looonie wrote:postfach wrote:if the a70 supra has the same lock as the z20 soarer, you don't need any more lock, it's fine how it is
What on earth have you been smoking Alex?
A70/Z20 have apalling steering lock factory. Removing the steering lock stopper bolts goes someway to improving it, but lock spacers really are needed.
cptsideways wrote:]
So how was it done....
GZ20/MZ20/JZA70 etc subframe, JZZ30 bottom arms, tie rods, track ends & hubs using the original upper arms. You'll need to shorten the tie rods & track rod ends by 15mm as they need to be screwed in quite a way. The hubs steering arms have been shortened by 50mm to delete the ackerman system, cut & rewelded job.
My old system had the rack ends spaced out, you won't be needing that any more just the standard rack system.
You'll need to add some spacers welded to the inside of the subrame mounts to pack out the difference in the bushes (JZ ones are 5-10mm shorter) The JZ arms also give more castor about 5mm further forward on the outer joint. Not measured it but its lots.
Not sure how legal this might be for the road but its a track car
