****anther problem on 4agze turbo fuel on plugs****
Postby corolla gt » Mon Feb 11, 2008 8:14 pm
i have checkd all the spark and leads and they are sweet but wen i start the car it fouls up the plugs straight away with fuel on them...there is fuel on the top ov my pistons...soon az i clean the plugs it starts again then it stalls
i have 440cc vr4 injecters link computer and im thinking maybe the car is runnnig really rich with fuel becuase the smoke is grey coming out ov the exhaust
is there anyway i can make the ar run not so rich on these injecters just 2 get it runnnig? the link computer has been changed to 4age sub board so that should be sweett
any help because after i have done this problem its going to a shop and they are goning 2 fix it haha :lol:
CURRENT:TOYOTA 1993 Hilux surf
OLD:TOYOTA 1995 HIACE SUPERCUSTOM TOYOTA SPINTER GT 1985,TOYOTA COROLLA GT 1986 (SMALLPORT)
corolla gt
Postby evil_si » Mon Feb 11, 2008 8:26 pm
have you got an adjustable fuel reg?
what sort of fuel pump have you got?
id drop the fuel pressure down to about 25-30psi and see what happens,
evil_si
Postby corolla gt » Mon Feb 11, 2008 8:39 pm
i have a ajustable adfter market fuel reg and i have a vl turbo fuel pump
i have the fuel reg at 2 bar right now is that 2 much
corolla gt
Postby l1ttle_d3vil » Mon Feb 11, 2008 8:42 pm
my engine filled with fuel when I had my injectors wired wrong. I had 12v + going to them, then earthed the other side out so they were open constantly :lol:
it would literally fill the engine with fuel, then I could turn the fuel pump off and start the car and have it run for about 30 seconds :lol:
2 bar is 29psi so should be about right. I was running a VL pump on my old n/a 4age which was about 38psi from memory.
Postby flygt4 » Mon Feb 11, 2008 8:42 pm
thats 28psi, so bout right i'd say.
definately souds like too much fuel, but why? its always something really simple.
flygt4
Postby Crucible » Mon Feb 11, 2008 9:00 pm
Seems like the injectors are WO, check to see if they are pulsing with a screwdriver to your ear, or use an led if you can get one to check the triggering.
thats all it can be if the fuel pressure is right...
Crucible
Real Life Mechanic
Postby Crampy » Mon Feb 11, 2008 9:02 pm
What map is in the computer?
Tow it to a place that can pull some of the fuel out of it and then get it tuned properly.
Crampy
Postby Crampy » Mon Feb 11, 2008 9:06 pm
A dude at work had a problem when he installed an Apexi computer into his Altezza. Turned out to be and earthing problem, causing the injectors to be on constantly.
Check all the earths and wiring for your Link. There seems to be a lot of faults with ECUs coming in recently.
Crampy
Postby fx gt » Mon Feb 11, 2008 9:32 pm
l1ttle_d3vil wrote:my engine filled with fuel when I had my injectors wired wrong. I had 12v + going to them, then earthed the other side out so they were open constantly :lol:
how did you have the injectors wired rong? think i might have same problem :P
fx gt
Postby RedMist » Mon Feb 11, 2008 10:28 pm
The other possibility is you have been running too much duty cycle and the injectors are fused open.
Are all four plugs wet? Are you using more than one injector trigger?
An earth fault wont generally take out more than one trigger (I used to wire my LEM's 1 and 4, 2 and 3, earth fault once made 2 and 3 not fire) where as too much duty cycle may take out some or all injectors.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby gepsk8 » Mon Feb 11, 2008 10:55 pm
u need as atleast 35-40psi to get a gud spray pattarn out of injectors,
need to get ecu tune i sounds like.
O272754663
gepsk8
Postby corolla gt » Tue Feb 12, 2008 6:26 pm
YEA ALL THE 4 PLUG ARE WET SO YEA I GTA DO SOMETHING BOUT IT MAYB GET TUNED SO THE LINK CAN B SET UP BUT I HAVE TO SUSS THE SMOKEY PROBLEM OUT 1ST
corolla gt
Postby ~SlideWays~ » Wed Feb 13, 2008 12:59 pm
I think you should sell it to me :wink: Got any pics of it yet?
~SlideWays~
Postby Crampy » Wed Feb 13, 2008 1:53 pm
Have you got a good breather setup for it? The stock single breather is no where near good enough for a turbo set up. I've used two oil filler cam covers as it gave me a second breather outlet. A few others have done similar. It's pretty cheap too, especially if you have spares lying around.
Crampy
Postby escortman » Wed Feb 13, 2008 5:15 pm
yep i did wat robin did fixd my problems
4x4 toyota blizzard offroader
escortman
Postby corolla gt » Wed Feb 13, 2008 10:33 pm
so j ust putt on another cam cover with the oil pipe on it and just have it goin into atmosphere? ....
corolla gt
Postby escortman » Wed Feb 13, 2008 10:39 pm
atm i have mine going into a pumpa nd coke bottle hahah until i my m8 finishs the 1 hes making me
escortman
Postby Crampy » Thu Feb 14, 2008 3:27 pm
Oil catch can with a filter on it.
With two breather cam covers, you'll need a catch can with two inlet pipes and the outlet on top with a little air filter.
Crampy
