Is the cam drive wheel on the crank different between
a Silvertop 20V and a Blacktop 20V?
Here's what I found.
I line my engine up with the notch on the cam drive sprocket with the dimple on the oil pump housing like you are meant to do to do cam timing,
and the engine is not at TDC.
This is a Blacktop oil pump and a Silvertop cam drive.
With a Silvertop oil pump and a Silvertop cam drive,
the same marks line up and it is TDC.
The keyway is fine and in the correct place,
as when you fit the front pulley, the TDC marks on it are correct?
matt
