Metal flakes in radiator?
Postby el_superhombre » Tue Feb 26, 2008 4:17 pm
My new car (92' MR2 G-Limited) has many small, copper coloured metal flakes around the radiator cap and a few floating in the radiator water around the fill line.
Does anyone know what this is and if they are a sign of corroding pipes or something bad? And, would a radiator flush be the best option to clear them away?
el_superhombre
Postby tatsumaki » Tue Feb 26, 2008 4:43 pm
Maybe the last owner through some stop leak down it?
Paul.
tatsumaki
Postby sergei » Tue Feb 26, 2008 5:15 pm
copper flakes? did it had headgasket done? many it is excess of copper coat?
Postby crispy'86 » Tue Feb 26, 2008 5:37 pm
Are they copper coloured and really tiny flakes or really rusty brown coloured and large? If they are tiny and a copper gold colour then chances are someone had put stop leak in the coolong system, possibly to stop the coolant pipes that run the length of the car, from leaking or other leaks. If they are rusty brown large flakes then the cooling system has more than likely been abused, pretty uncommon to have large flakes in the radiatopr that large but, you never know
crispy'86
Postby el_superhombre » Tue Feb 26, 2008 5:50 pm
crispy'86 wrote:Are they copper coloured and really tiny flakes or really rusty brown coloured and large? If they are tiny and a copper gold colour then chances are someone had put stop leak in the coolong system, possibly to stop the coolant pipes that run the length of the car, from leaking or other leaks. If they are rusty brown large flakes then the cooling system has more than likely been abused, pretty uncommon to have large flakes in the radiatopr that large but, you never know
I am starting to believe that it might be stop leak. The flakes are tiny and are more of a bright copper colour than rust. Would you recommend a flush or would that just make my radiator spring what ever leaks the stop leak plugged?
el_superhombre
Postby flygt4 » Tue Feb 26, 2008 6:03 pm
i'v eput stop leak in a radiator before. its bloody nasty stuff man :lol:
flush it and refill and see if it starts leaking. i doubt it will.
flygt4
Postby tatsumaki » Tue Feb 26, 2008 7:58 pm
Only one way to flush it properly dude, take it to a radiator shop and get them to flush it out properly ... get it back flushed.
When I was at Geartech even radiator that came out for cleaning/flushing got sent off to the radiator shop.
Paul.
tatsumaki
Postby BlakeNZ » Wed Feb 27, 2008 9:30 am
it is a particular brand of radiator stop leak.
BlakeNZ
Postby crispy'86 » Wed Feb 27, 2008 12:11 pm
el_superhombre wrote:I am starting to believe that it might be stop leak. The flakes are tiny and are more of a bright copper colour than rust. Would you recommend a flush or would that just make my radiator spring what ever leaks the stop leak plugged?
That may or may not cause the core or tank to leak, it really depends where the leak was originally but, if you take the radiator into a radiator shop they should flush it and then pressure test it and report back if there are any leaks. What does the core look like in the radiator itself??
crispy'86
Postby tatsumaki » Wed Feb 27, 2008 3:07 pm
crispy'86 wrote:What does the core look like in the radiator itself??
Probably the most important question to be asking here ^^^
Paul.
tatsumaki
Postby el_superhombre » Wed Feb 27, 2008 4:55 pm
Paul.
What exactly is 'the core'? Is that the fins of the radiator?
el_superhombre
Postby tatsumaki » Wed Feb 27, 2008 8:26 pm
Yes. You have the top tank and the bottom tank. The bit in the middle is the core.
Paul.
tatsumaki
