What does this dash light indicate?
Postby Calvin » Thu Mar 27, 2008 9:41 pm
its a rectangle with squiggly lines coming out the top
Whats does it mean when lit up??
Calvin
Postby Lloyd » Thu Mar 27, 2008 9:42 pm
Cat temp warning light?
Postby Calvin » Thu Mar 27, 2008 9:43 pm
HRT wrote:Cat temp warning light?
Yeh thought it was to do with exchaust.. where is the sensor?
Calvin
Postby Lloyd » Thu Mar 27, 2008 9:51 pm
It'll be the only other wire coming out of your exhaust that isn't the oxygen sensor. More than likely just behind the firewall
Postby cat007 » Fri Mar 28, 2008 9:01 am
It'd be further back than that wouldn't it?
Postby sergei » Fri Mar 28, 2008 9:11 am
it will be right in the cat.
My selica loved to put this light on for anything
Postby Capin-Neemo » Fri Mar 28, 2008 10:46 pm
My old celica likes to give me cat warnings for everything did a manual conversoin forgot to bolt in the sensor light came up couldn't reach it so said $&#$% it cut the sensor off light went out. then it came on when ever it damn well liked cold, hot not even running.
My advice pull the buld out of the dash in NZ waste of time!
Capin-Neemo
Re: My selica loved to put this light on for anything
Postby matt dunn » Fri Mar 28, 2008 10:55 pm
Capin-Neemo wrote:My advice pull the buld out of the dash in NZ waste of time!
Comes on whan the cat is too hot,
which can be cause by fuel getting into to from a missfire, or the cat is partially blocked, or lots of other reasons.
Dont just remove the light as there is a problem somewhere.
May have to get the cat removed.
Matt
Postby Capin-Neemo » Fri Mar 28, 2008 10:57 pm
True true my bad on the hate CAT's front lol....
check it out first of course my experiance is with old cars 95 or older and most of those the cats are poked so we just ditch them and kill the warning lights :!:
Capin-Neemo
Postby Calvin » Sat Mar 29, 2008 7:57 pm
sweet, my exhaust doesn't have a cat so i figure once i find out what the light does to not hook it up in my ae92.
Calvin
Users browsing this forum: Yahoo [Bot] and 7 guests
