(1KZ-TE) Diesel Injector/Glow Plug Query
Postby Muzzie » Mon Apr 07, 2008 12:32 am
Diesel Injectors.....
How often should they be removed and either cleaned or replaced?
What cost am I looking at to do that?
Oil & filter changed every 5000km, fuel and air filters done every 20,000km so it's been looked after, but it's got 180,000km on it so I guess they're due for something?
And whats the go with glow plugs? Do you just replace them when they start dying/making motor harder to start.
Mobile Car Servicing & Audio Installation - Inquire!
I'm Not Dumb, Im Just Selectively Observant!!!!
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1036
Had flash sig, but too big for TS :(
Muzzie
Regular Poster
Postby Zak » Mon Apr 07, 2008 8:30 am
We've never replaced any at work. I guess you could take them out and clean them, but they would be unlikely to fail.
I've found a new battery fixes most problem people think are the glow plugs, but you can't say with out checking it.
Zak
Postby Lloyd » Mon Apr 07, 2008 8:35 am
No need to ever do injectors unless you start having running issues. Glow plugs just do when you notice its starting a bit harde or starting rough for a few seconds (starting on 3 basically). Easy enough to test them, can either do one or the lot each time. At $20 a plug probably just do the dead ones.
Postby Mr Revhead » Mon Apr 07, 2008 9:01 am
yeah the 1kz doesnt seem to have many issues with glowplugs.
sell a few 2l and 3l ones but bugger all 1kz.
Postby hsmidy » Mon Apr 07, 2008 1:31 pm
yeah dont even bother looking at your injectors unless your having sum running issues
hsmidy
Postby Muzzie » Mon Apr 07, 2008 10:27 pm
Sweet, thats good to hear.
Not having any starting problems (maybe ticks over one more compression when cold before catching) and definitely not having running problems.
Saves me some money then :) Just keep driving and servicing it then :D
Muzzie
Regular Poster
