Maxwedge wrote:Does anyone know what power is lost through the driveline as a percentage? So if a smallport for example is putting 100 Kw through the flywheel, what would this equate to at the wheel once friction etc is calculated?
Akane wrote:While we're on the subject, you hear a lot of kiddies saying taking 15% drivetrain loss or some crap and boast their "flywheel figure"
Just think of it this way, say 200kw, losing 15% = 30kw? most of that energy would be converted to HEAT. 30kw of heat is like having a furnace cooking your gearbox and diff. Not going to happen.
I get 292hp at the wheels, I'd say my flywheel would be 310hp max.
Edit: oh, there's a very "famous" tuner in New Zealand, who a lot of people thinks is a very good tuner, but imo all the dynos that company produces are BS. Like making 252kw @ rear wheels with factory SR20DET injectors. :/ Just imo tho.
Akane wrote:Just think of it this way, say 200kw, losing 15% = 30kw? most of that energy would be converted to HEAT. 30kw of heat is like having a furnace cooking your gearbox and diff. Not going to happen.
stalker wrote:Is there a way to work it out though??
Ie. I got my car dyno'd and was told I had 118kw! (woot) But then I looked and saw that the dyno sheet said that was at the flywheel...how did they get that if id was sitting on a hub dyno??? And how do I work out what the "at the wheels" figure would be??
method wrote:Akane wrote:While we're on the subject, you hear a lot of kiddies saying taking 15% drivetrain loss or some crap and boast their "flywheel figure"
Ive heard figures up to 30% for 4wd drivetrain loss.
Remember the engine is under full load, it pretty much is a furnace under full loan and you will have things glowing red and breaking in no time.
And i took my 1530kg car to this famous tuner, got 194kw at the wheels then managed to run a13.0 backed with a 13.06 at meremere which is pretty quick considering the weight and the amount of power it out out. On regular street tyres too.
