Replacing Side Light on 97 Curren
Postby callum_62 » Sun Apr 27, 2008 12:18 pm
Hi,
Im gonna ask a really dumb question, but as a car novice, I dont wanna break anything for the sake of a lightbulb!
Basically, my right side 'position' light on my 97 Curren has blown.
Got the new bulb etc to fit, thinking it would be a 5 min job, I mean, its only a lightbulb! Trouble is, its a bit of a bugger to get into the side light (infact, im not 100% sure how its done).
I have unscrewd the screw that obvioulsy holds the whole side light swction in place (just under the bonnet).
This makes the panel loose etc....but what now? Do I just use a flat head to pop the panel out to get access to the bulb? I just dont wanna break anything, for the sake of a $4.50 bulb!
Also, a bit embaressed to take a light into a garage!
Any help would be appreciated,
Thanks!
callum_62
Postby Jdawg » Sun Apr 27, 2008 4:30 pm
The whole light assy should just pop off the front. It is held in by a ball/socket set up, once you have the screw off use a screwdriver to lever it off nice an easy like. Replace your bulb then line it up and push it back on then put the screw in.
Jdawg
Users browsing this forum: Bing [Bot] and 12 guests
