Quick ST16* Question
Postby AE86less » Thu Jun 05, 2008 2:24 pm
I have just heard that the ST16* celica that came with the 5SFE engine had 4x100 hubs. Is this true?
Also, I don't suppose if anyone knows offhand if those hubs have the same splines as a ST202 halfshaft? :oops: :lol:
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby MrOizo » Thu Jun 05, 2008 3:19 pm
There was a AT162 (with 4AGE) which had the 4x100 hubs.
The 5SFE was a USDM in the ST18* series. i'm sure one of the celica nuts will correct me though :)
MrOizo
Toyspeed Legend
Postby AE86less » Thu Jun 05, 2008 3:40 pm
Dumb :x
If it's 4age then chances are the splines won't be the same, right?
I saw one of those AT16* celicas at pickapart a few months ago...
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby sergei » Thu Jun 05, 2008 3:43 pm
Splines in the hub are the same.
5SFE comes in export versions only and in only ST18X-ST20X series as far as I am aware.
2S(E) will have 4x100 hubs.
3S(F/G)(T/E) will have 5x100 hubs.
A powered will have 4x100 hubs.
Postby AE86less » Fri Jun 06, 2008 11:23 am
Sweet, that's really good to know. Cheers Sergei.
EDIT: The brief research I just did has showed that the 2S engine is a 2L EFI engine? Correct?
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby sergei » Fri Jun 06, 2008 11:54 am
AE86less wrote:Sweet, that's really good to know. Cheers Sergei.
Could be, 2SE, also I have seen (if my memory is correct) 2Si which is single point injection, also they came out with carb. Also there was a 1S version as well (which is 1.8L).
Postby AE86less » Fri Jun 06, 2008 1:08 pm
Did the 1S come in things like Coronas and Camrys? I'm going to be keeping an eye on the pickapart website and TM etc :wink:
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby SUBARUCONVERT » Sun Jun 08, 2008 3:10 pm
1s's come in early series ST15X nz new and jap coronas in FWD config. you can also get celicas with the 1s and 2s in RWD, kinda rare tho
3ST150
SUBARUCONVERT
