*AltezzaRS200* Good Tune VS Bad Tune... You decide...
Postby barryogen » Tue May 27, 2008 6:15 pm
Distrb wrote:Most use the gear thats closest to 1:1 ratio that allows a full plot over the rev range. For instance in altezza with factory ecu, they hit speed cut in the 5th gear (1:1 ratio) before they reach their rev cut. So drop back to 4th.
Handy to know.
barryogen
2ZZ Guru in training
Postby Titties » Wed May 28, 2008 8:24 am
Does anywhere still do dyno days?
$50 for 2WD etc...
i dont really wanna pay $150 for a power run to make my figures comparable.
xnickx where did you get yours dyno'd ?
'98 RS200 Altezza - SOLD
'96 Mitsi Mirage, 11.12 @ 124mph (200kph)
Titties
Postby xnickx » Wed May 28, 2008 9:35 am
Mine was done at Torque Performance, they normally do open dyno days every first Saturday of every month.
But they have just moved from Fremlin Place to Patiki Road so best to contact Robin there first
xnickx
Postby RomanV » Wed May 28, 2008 11:02 am
And they dont do monthly dyno runs anymore. :cry:
(Not allowed to thanks to whinging neighbours, or something)
Postby xnickx » Wed May 28, 2008 11:29 am
Are you sure?
Shouldnt be whinging neighbours cause they have moved to a new location perhaps?
RomanV wrote:And they dont do monthly dyno runs anymore. :cry:
xnickx
Postby Titties » Wed May 28, 2008 1:06 pm
just called Robin, he said they dont do Dyno days anymore, and it's $225 for a power run (for 2wd car, my altezza)...
So yeah, dont know whats up with that.
Titties
Postby IH8TEC » Wed May 28, 2008 1:07 pm
damn thats crazy :?
Postby xnickx » Wed May 28, 2008 1:25 pm
Bum!
Know that On The Limit Motorsport and MagandTurbo here on the shore have their own dyno now, power runs are $100 regardless if your 2WD or 4WD
Ouch!
Shore Performance have a dyno too maybe drop them a line perhaps
xnickx
Postby barryogen » Wed May 28, 2008 1:31 pm
If you think of a dyno day as entertainment(cause really it's not much more), then $100 for a couple of hours isn't bad...
I could think of better ways to blow $100, but thats a different discussion all together. :lol:
barryogen
Postby RomanV » Wed May 28, 2008 1:37 pm
barryogen wrote:If you think of a dyno day as entertainment(cause really it's not much more),
I've gained a fair bit of useful information by taking my car back to dyno day at TP with a slightly revised setup each time.... Something you cant do if you've paid for a few hours on the dyno. Unless you want to be paying them by the hour to watch your exhaust cool down enough till you can swap it for a different setup, or fiddle around with your intake, or... whatever.
RIP TP monthly dyno days, you will be missed. :cry:
Postby xnickx » Wed May 28, 2008 1:49 pm
RomanV wrote:RIP TP monthly dyno days, you will be missed. :cry:
Indeed!!!
xnickx
Postby ROBODISCO_20v » Mon Jun 02, 2008 1:14 pm
Should hit NZPC mag up see if they can organize dyno days again. I went to one of theirs at TP when I had the Levin. $50 2WD or $60 with lambada.
But I guess like everything of late the price will be nearly double what it used to be...
ROBODISCO_20v
Postby barryogen » Mon Jun 09, 2008 10:59 am
*edit* AFR was between 12.7 and 12.9 right through the rev range.
I'm very happy with the gains through the rev range, overtaking is no much easier, and fuel consumption on the return trip appears to be far less(14%) than the trip up there, even with a head wind on the return... and I was driving considerably harder on the trip home.
Oh yeah, tuned on Shell V-power(their new 95, co-developed with Ferrari... yeah right)
barryogen
Postby Titties » Mon Jun 09, 2008 12:42 pm
nice!
what ecu are you running?
Drags grudge match imo!
Titties
Postby barryogen » Mon Jun 09, 2008 1:02 pm
Power FC.
4 hrs, and ~$500 bucks later I drove away with a car that goes heaps better.
I'm just glad that there is no knock now. :)
that and I'm paying less per litre than you :P
barryogen
Postby Titties » Mon Jun 09, 2008 1:26 pm
is the red line the base map and the black line the latest tune?
Or is the red a previous tune?
Titties
Postby barryogen » Mon Jun 09, 2008 1:53 pm
the lower line is what state it was in prior, which was fairly close to the factory power FC tune, way too advanced timing up to 3500RPM, and way too rich apparently.
The point where it is making marginally less power is when it was knocking badly on the previous tune.
barryogen
Postby nite b » Mon Jun 09, 2008 7:28 pm
High Velocity dyno in Glenfield.. Bout $90-100 for power runs. Got a couple other Altezza 3SGE graphs from there if you ever get something to compare from there.
Found it to be very accurate and have worked back HP figures from cars that have been engine dyno'd & pretty much spot on.
Have redyno'd cars after 2-3 months with no changes and within 1rwkw each time!?
Anyways,had much good experience with this dyno. Not the biggest figures for bragging rights, but consistent, unbiased and accurate.
:D
Convert Ltd
The conversion specialist
nite b
Users browsing this forum: Google [Bot] and 20 guests
