Dragger_Dan wrote:What exactally does the charcoal can do? Is it for recycling the fumes from the tank or something?
no_8wire wrote:yes you need it...unless you want your car to go up in flames...
not_paul_from_waiheke wrote:what happens when the turbo is pushing 1 bar through the vacuum hose into the charcoal canister?
RunningRich wrote:You mean pushing 1 bar aginst the one way check valve between the manifold and canister![]()
RunningRich wrote:It isn't needed. Mine vents straight to atmosphere. My intention was saving (a little) weight and also reducing the complexity in the engine bay.
