I need to setup the boost control on my Link G3, using a Link boost control solenoid. Preferably I would like to have a switch so I can alternate between low and high boost. just need someone to confirm the wiring for it so I can get it wired up ready for the tuner setup on the dyno.
so...
12v + to the solenoid
Aux output to the solenoid
then the digital input goes to a switch, with the other side of the switch connecting to an earth. correct?
otherwise, is there any reason a switch can't just be installed inline with the aux output?
when the switch is off, the solenoid won't be energised and will run the factory boost.
when the switch is on, the solenoid will be energised and control the boost at the chosen setting.
